IOS restore problem in ASA5520
shahid_duet
Dear boss
I have erease flash somehow as i can to boot asa 5520. Then i go rommon and have tftp.Then login.
I got all my configuration. Then i do :
ASA5520(config)# boot system disk0:/asa708-k8.bin
ASA5520(config)# asdm image disk0:/asdm-508.bin
ASA5520# write memory
ASA5520# reload
Then no boot file found and some message like undable to boot......
What can i do now ?
how to boot ?
Thanking You
shahid
varrao
Level 10
Level 10
Hi Shahid,
Try loading the image from rommon mode:
Step1 Power  off the adaptive security appliance, and then power it on.
Step 2 During  startup, press the Escape key when  you are prompted to enter ROMMON mode.
Step3 In  ROMMOM mode, define the interface settings to the adaptive security appliance,  including the IP address, TFTP server address, gateway address, software image  file, and port, as follows:
rommon #1> ADDRESS=10.132.44.177
rommon #2> SERVER=10.129.0.30
rommon #3> GATEWAY=10.132.44.1
rommon #4> IMAGE=f1/asa800-232-k8.bin
rommon #5> PORT=Ethernet0/0
Please make sure that the Tftp  server is connected to the interface.
Step 5 To  validate your settings, enter the set command.
rommon #6> set
Step 6 Ping the  TFTP server by entering the ping  server command.
rommon #7> ping server
Step 7 Load the  software image by entering the tftp command.
rommon #8> tftp
Step 8 Reload  the security appliance to run the new image.
rommon #9> reload
Once the ASA comes up, check "show flash" the image should be there in flash, and then set the boot parameters.
HTH.
Varun
Varun Rao
varrao
Level 10
Level 10
Hi Shahid,
rommon #6> set
rommon #8> tftp
rommon #9> reload
HTH.
Varun
Varun Rao
Thanks varun
