IPS not detecting packets Entering & Exiting Same Interface
shahedvoicerite
Level 6
Level 6
Consider scenario :-
Host A--->Router B--->Router C
All are in the same subnet
Router C also has an active interface on another subnet.
When I telnet from A to C (interface with ip address in another subnet),
I force traffic from A to C to pass through B, by setting static routes AND ** DISABLING IP REDIRECTS ***
Trafic flows from A to B IN through Fa0/0, and OUT again through Fa0/0 from B to C
I have ACL's (permit/log) that show this flow !!!!
I also have IPS enabled in/out on Fa0/0 on router B.
However, traffic flowing through Router B, which enters / exits the same interface, does not get picked up by IPS. (I trigger signatures)
Is this normal ?? Or am I missing something ?
5 Replies 5
smalkeric
Level 11
Level 11
This module describes how to configure the Cisco IOS Intrusion Prevention System (IPS), which helps to protect a customer's network from internal and external attacks and threats. Cisco IOS IPS restructures and replaces the existing Cisco IOS Intrusion Detection System (IDS).
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804453cf.html
mhellman
Level 11
Level 11
I don't use the router IPS, but I'll give it a shot;-) I don't understand the network config. I'll try to redraw the network to see if I understand what you're saying:
Host A
(NET1/IP1)
-------- (NET1/IP3) Router C (NET2/IP4)---
(NET1/IP2)
Router B
Host A uses Router B as its gateway to NET2 and since redirects are disabled on router B, all traffic from Host A to IP4 flows through router B. If the diagram above is correct though, return traffic from router C will not be routed through Router B because the destination is on the same network as router C. How are you getting return traffic to flow through router B?
Based on the following doc:
http://www.cisco.com/application/pdf/en/us/guest/products/ps6634/c1244/cdccont_0900aecd80327257.pdf
If you're attempting to fire atomic signatures (single packet) then signatures should still fire anyway when inspected inbound. If you're attempting to trigger a stateful signature then this would be a plausible explanation.
Yes, your understanding of my network setup is correct.
Yes, return traffic does not go through B, but that is not the issue here, as I am trying to pickup STRING.TCP packets, which I believe as you mention are ATOMIC.
i.e a telnet connection from A to C, and if I type the word "ATTACK" in the session :-
Router B should detect the string match and drop the connection.
The telnet packets I believe with the word "ATTACK" in this case wold go from A->B inbound and B->C outbound on the same FastEthernet port.
I have the ips detection enabled both inbound and outbound on the Fa0/x port.
Have you gotten a trace to ensure that the characters you typed in actually resulted in the string ATTACK being sent in a single packet? I think you'll find that this is not the case with telnet. My recollection is that each letter you type will be sent in a separate packet.
Hi again,
No, I dont have a trace 😞
Perhaps you may be right about the "statefull" versus "stateless" inspection problem going on in my case.
I am going to experiment, by setting a route map on the target router (C) and force traffic back through (B).
I will also try other real "ATOMIC" tests.
Thanks.
