IPS Signature versions doesnt match from system info and dashboard
applegreen
Hi, I have a customer who has a IPS runing version 6.2(1)e3. after the last auto update, the sig version from the asdm system info shows 377, however from the IDM health dashboard, the sig version shows 373, I am wondering if someone can provide some suggests what might cause the problem, thanks in advance
applegreen
Any feedback and suggestions on this one please?
When this happened to me, I rebooted the sensor and fix it. If the IPS sensor is "inline", be sure you are in Auto bypass mode. Meaning - if the sensor fails, traffic is not halted.
Hope this helps.
If this posts answers your question or is helpful, please consider rating it and/or marking as answered.
Hi, I will let customer try. thanks a lot for the tip
