IPSEC problems after upgrade to 8.0(3)
ciscovertis
After upgrading my asa devices (2*5510) I started to getting odd messages which relate to lan-to-lan connection between these:
Dec 4 03:18:15 stasa1 %ASA-3-713227: IP = A.B.C.D, Rejecting new IPSec SA negotiation for peer D.C.B.A. A negotiation was already in progress for local
Proxy x.x.x.x/x.x.x.x, remote Proxy x.x.x.x/x.x.x.x
Dec 4 03:18:15 stasa1 %ASA-3-713902: Group = A.B.C.D, IP = A.B.C.D, QM FSM error (P2 struct &0xd8c23fc8, mess id 0x132546bb)!
Dec 4 03:18:15 stasa1 %ASA-3-713902: Group = A.B.C.D, IP = A.B.C.D, Removing peer from correlator table failed, no match!
At same time, users complain that their connections were reset. I think that there were no problems when we were running 7.3.
I wonder if there is something in the configuration I'll have to change after upgrade ?
ciscovertis
I just solved the problem after forcing a failover to our secondairy asa.
