Issue Power Supply
gigin1234
Dear Cisco Community,
Hi Everyone, I have issue about FIresight. on the "System -> Health" there are message "Power Supply status is Input Los" but The 3D Sensor is running. the question is :
 a) why this happened ?
 b) What caused it ?
 c) how to solve this issue
I just say thank so much for sharing.
Gigin
danholland1
You possibly have a failed power supply.  From the CLI you can run: show power-supply-status.  This will give you output like this:
--------------[ Power Supply Status ]---------------
Power Supply 1 : Present
Power Supply 1 : Connected to power source
Power Supply 2 : Not Detected
Power Supply 2 : Not connected to power source
Contact Cisco for a possible RMA of that power supply. I have about 130 sensors in our environment and have had many power supply failures, and all have ended up in RMA.
