Issue while going to context through Switch...
shain bharati
when i go to the context through switch then i am not able to do anything. i am able to go to one context but then the session gets locked, means i can not run any command not even go back to the system context or any context. i have to close and open a new session.
i get this messege: not authorised.
I can acces FWSM directly but not through SWITCH.
Please help me.
Thanks in advance,
Shain Bharati CCIE (R&S) #28837
Jennifer Halim
"Not authorised" seems to imply that you have configured authorization to disallow access.
Can you share the system and admin context config.
Jennifer,
this is aaa configuration,
aaa authentication enable console ACS LOCAL
aaa authentication ssh console ACS LOCAL
aaa authentication http console ACS LOCAL
aaa authorization command ACS LOCAL
aaa accounting enable console ACS
aaa accounting ssh console ACS
aaa accounting telnet console ACS
aaa accounting command ACS
I just removed
and working fine, but this is temparory solution, we do not want to remove this command.
please let me know if you have some permanent solution.
Shain Bharati
Since authorization is done by ACS server, you would need to check what you have configured on the ACS server that has prevented the access.
