Issue with 1120 connecting to meraki ms350
Artezys79
Hi All,
My task is to replace existing mx device with 1120 and connect to the MS350 upstream, which is cloud managed and requires access via VLAN1. 1120 ia managed via Cisco FMC. Giving that, I am unable to implement VLAN 1, which is necessary for Meraki to comunicate, as on 1120 I am able only to create subinterfaces and cannot tag interface as I would on 1010, for instance.
Please advice correct way for implementation.
Mark Elsen
   - You may also ask the question in https://community.meraki.com/t5/Switching/bd-p/switching
   M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
are this issue solved ?
MHM
