Issue with NAT Configuration and Port Forwarding in Cisco Packet Trace
Emirates
I am currently learning about NAT using Cisco Packet Tracer. I have set up a web server named www.isp.com with the IP address 209.165.100.12. I configured NAT on the ISP router and also set up static port forwarding using the following command:
ip nat inside source static tcp 209.165.100.12 80 209.165.110.3 8080
interface Gig0/1
ip nat inside
exit
interface Serial0/0/0
ip nat outside
exit
When I access the local IP in my web browser (209.165.100.12) from the DNS server 209.165.100.11, the website is displayed without any issues. However, when I try to access the website using the public IP (209.165.110.3), I receive a Request Timeout error.
I have tested it from various clients within my Packet Tracer environment. I have uploaded the Packet Tracer file and my configuration commands directly. Can someone please explain where my mistake might be?
Paket Tracer File: https://easyupload.io/w9svqs
Here the running-config of the ISP Router:
ISP#show running-config
Building configuration...
Current configuration : 1145 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname ISP
no ip cef
ipv6 unicast-routing
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX15242AUZ-
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
ip address 209.165.100.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ipv6 address 2001:DB8:AB:1::1/64
ip address 209.165.110.1 255.255.255.248
ip nat outside
ipv6 address 2001:DB8:AB:AB00::1/64
clock rate 2000000
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip nat inside source list 1 interface Serial0/0/0 overload
ip nat inside source static udp 209.165.100.11 53 209.165.110.4 53
ip classless
ip flow-export version 9
access-list 1 permit 209.165.100.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
end
6 Replies 6
Why it not work?
How you check ?
I have verified this using a web browser (please refer to the screenshot). Additionally, I attempted to create a complex PDU using HTTP, but all my attempts were unsuccessful.
If I configure a static route on R1 (ip route 0.0.0.0 0.0.0.0 192.168.2.1), the connection appears to function properly from the admin computer. However, I'm curious why setting up the default route is necessary? Additionally, I'm puzzled as to why it doesn't work from the DNS server?
Remove server and add it again and check.
This PKT and there are many bug
Hello
Thank you. I tried but it didn't seem to work. If I configure a static route on R1 (ip route 0.0.0.0 0.0.0.0 192.168.2.1), the connection appears to function properly from the admin computer. However, I'm curious why setting up the default route is necessary? Additionally, I'm puzzled as to why it doesn't work from the DNS server?
balaji.bandi
as per the diagram, i think you have routing issue here,
you have attached some config, which is not clear , what routing in place
can you  try from ISP router are you able to ping 209.165.100.12
i see in the config you have many NAT in the routers, if that is case where is the web server configured (i see ww.isp.ch) - dont see www.isp.com on the diagram. ISP router which side inside and outside ?
BB
Thank you very much for your response. I've successfully pinged the web server from the ISP (which is actually www.isp.ch
However, I should clarify that the ping for 209.165.110.3 isn't working because it only responds to HTTP requests (ip nat inside source static tcp 209.165.100.12 80 209.165.110.3 8080). If I attempt to access the website from the DNS server using the local IP, it works fine:
But when I try to access it via the IP 209.165.110.3, it doesn't work:
