Java problem when accessing PIX 506e
mburns
Community Member
I get an error message when I try to access my PIX 506e from within the firewall using IE. after the first password I get the error message "exception: java.security.AccessControlException: access denied(java.utilProperty Permission java.versionread)at the bottom of the IE page. Any ideas?
satish77
hi burns i had the same problem what u need to do is go to www.java.com and down load the java applet and try and acces the PIX will work without a problem
satish77
mburns
Community Member
Thanks, I'll try that. I was able to get it to work by restoring the computer to an earlier date.
