LAN failover using a redundant interface
cclem
If I want to use a redundant interface for the LAN based failover it is a requirement that I must put a hub or switch between the two ASA devices? I am attaching a couple of recommened scenarios from Cisco -- one without a switch and one with a couple of switches.  If I don't use a switch or hub, I am thinking that I could have the active port on the primary unit connected directly to the standby port on the secondary unit thus causing a failure.
5 Replies 5
padatta
Level 6
Level 6
Yes, it is a requirement to have a switch or hub between the two units in case redundant interface is used as failover link.
This is explained here: (check under 'For failover, follow these guidelines when adding member interface')
http://www.cisco.com/en/US/partner/docs/security/asa/asa82/configuration/guide/intrface.html#wp1062371
Paps
Thanks for the quick reply Padatta.  I was somewhat surprised to see the Cisco diagram showing the two failover links directly connected.
Andrew Ossipov
This scenario is supported with Redunant interfaces in 8.0(4) and later software. I will get the documentation corrected.
Andrew
Hi Andrew,
Just to clarify. Are you saying that LAN failover using a redundant interface without a switch or hub is supported in 8.0(4) or later software? I have tested both scenarios shown above in my lab using a pair of 5550's with software version 8.4 and have not seen any issues when directly connected or when connecting through a switch.
Charles
Hello Charles,
That is correct. You can use a pair of directly connected redundant intefaces as a failover or state link in 8.0(4), 8.1(2), and all of the later branches. The change to the configuration guides will be pushed out shortly.
Andrew
