LLQ Help required
wasiimcisco
Level 7
Level 7
I want to configure LLQ on my Router which has 2 FE interface.
I want only application always gets min 5990 Bandwidth in either case.
and one user get 8 kbps.
I configure the router with below mention command but still not able to get the desired result. both users are able to get bandwidth in MB and no LLQ is working.
version 12.4
class-map match-all testclass2
match access-group 160
match access-group 150
policy-map testpolicy
class testclass
priority 8
class testclass2
priority 74990
interface FastEthernet0/0
bandwidth 8000
ip address 10.1.3.1 255.255.255.0
ip nat outside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.1.4.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.3.2
ip nat inside source list 100 interface FastEthernet0/0 overload
access-list 150 permit ip host 10.1.4.3 any
access-list 160 permit ip host 10.1.4.5 any
Router-C#show policy-map interface fastEthernet 0/0
FastEthernet0/0
Service-policy output: testpolicy
Class-map: testclass (match-all)
91678 packets, 5680284 bytes
30 second offered rate 698000 bps, drop rate 0 bps
Match: access-group 150
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 8 (kbps) Burst 200 (Bytes)
(pkts matched/bytes matched) 9/612
(total drops/bytes drops) 0/0
Class-map: testclass2 (match-all)
144133 packets, 8696430 bytes
30 second offered rate 898000 bps, drop rate 0 bps
Match: access-group 160
Queueing
Strict Priority
Bandwidth 5990 (kbps) Burst 149750 (Bytes)
(pkts matched/bytes matched) 22/1251
Class-map: class-default (match-any)
27 packets, 2235 bytes
30 second offered rate 0 bps, drop rate 0 bps
6 Replies 6
abdul ilyas
Level 3
Level 3
I think you didnot apply the created policy to interface fa0/0 using command service-policy.
bandwidth 8000
ip nat outside
load-interval 30
duplex auto
speed auto
service-policy output testpolicy
Kindly see the updated configuration, but still the result is same.
Router-C#sh run
Building configuration...
*May 29 15:25:44.768: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 1247 bytes
version 12.4
hostname Router-C
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool users
network 10.1.4.0 255.255.255.0
default-router 10.1.4.1
voice-card 0
no dspfarm
class testclass
priority 8
class testclass2
priority 5990
class class-default
fair-queue
duplex auto
speed auto
duplex auto
speed auto
ip classless
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Router-C#
Router-C#sh run
version 12.4
hostname Router-C
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip dhcp pool users
voice-card 0
no dspfarm
class testclass
priority 8
class testclass2
priority 5990
class class-default
fair-queue
duplex auto
speed auto
duplex auto
speed auto
ip classless
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
Can you please post the outputs of following commands.
Router-C#show policy-map interface fa0/0
Router-C#show interface fa0/0
Please see the the output for following commands
Router-C#sh interfaces fastEthernet 0/0
FastEthernet0/0 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 001d.a16c.9b70 (bia 001d.a16c.9b70)
Internet address is 10.1.3.1/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:14, output 00:00:02, output hang never
Last clearing of "show interface" counters 20:47:27
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 7
Queueing strategy: Class-based queueing
Output queue: 0/1000/64/7 (size/max total/threshold/drops)
Conversations 0/2/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 69002 kilobits/sec
1568797 packets input, 2304073751 bytes
Received 4249 broadcasts, 0 runts, 0 giants, 0 throttles
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
831886 packets output, 50801301 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier
Router-C#sh poli
Router-C#sh policy-map
Router-C#sh policy-map testpolicy
Policy Map testpolicy
Class testclass
Strict Priority
Class testclass2
Strict Priority
Class class-default
Flow based Fair Queueing
Bandwidth 0 (kbps) Max Threshold 64 (packets)
Router-C#sh poli
Router-C#sh policy-map inter
Router-C#sh policy-map interface g
Router-C#sh policy-map interface fa
Router-C#sh policy-map interface fastEthernet 0/0
FastEthernet0/0
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Queueing
Strict Priority
(pkts matched/bytes matched) 0/0
161446 packets, 9746137 bytes
Queueing
Strict Priority
(pkts matched/bytes matched) 4/216
7562 packets, 773379 bytes
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/0/0
any update ???
Is this still an issue?
if so you are performing LLQ on an FE interface. LLQ will work when the interface is congested. The FW is not congested - and adding a bandwidth statement will NOT change the interface speed which will still be 100mbs.
What you need to do is not congestion management - you need to police and traffic shape!
