Load Balancing feature can possible between ISP and Tunnels on ASA?
nikuhappy2010
I have some idea which may be useful in the term of load balancing between tunnels and ISP links...just need to know is it possible or not....
I want to make a network like this with using two links.
Ist Link ISP Router A----ASA FW A--Inside Router A------Inside Network/DMZ A
IIst Link ISP Router B----ASA FW A--Inside Router A------Inside Network/DMZ A
ASA FW A outside Interace 1.1.1.1 connected with Ist ISP Link
ASA FW A outside 1 Interace 2.2.2.2 connected with IInd ISP Link
ASA Interface Inside 192.168.14.1
ASA Interface Inside1 192.168.13.1
Both Inside Interface are connected with Router Eth port and the 3 rd port of router is using for Inside Network (192.168.12.0)
I have created Tunnel on ASA to connect the DC network by configuring both Outsie interface. And both tunnel are working fine If i access by .13.0 or .14.0 network.
Now I set the comand on Inside router:-
Ip route 0.0.0.0 0.0.0.0 192.168.13.1
Ip route 0.0.0.0 0.0.0.0 192.168.14.1
Now in this scenario, can load balancing configre for both tunnels. I add the route comand on FW to tell the ASA for incoming traffic.
192.168.12.0 255.255.255.0 192.168.13.2
192.168.12.0 255.255.255.0 192.168.14.2
22 Replies 22
"Now wud to like to know if i use static routes instead of dynamic routing then why it wont be best practise"
Sure. Lets take the following example
This route will stay in the table as long as the inside router's relevant interface is Up. And if interface goes down, this route will get passive. Thats great. If that interface fails, all traffic will be routed through other route only.
But if something happens to link between ASA and ISP router, Or ISP routers internet link goes down, or Site-To-Site VPN tunnel goes down, Inside router will have no idea if they are down or not and keep the route which is actually dead at far end, and your traffic will be load balanced which the packets that are routed wia that dead route will be dropped.
Dynamic routing protocols are a piece of cake. I wrote the necessary commands in the topology that I drew for you (I hope you downloaded it).
Can you show me any example which is related to Interested Traffic as you mentioned that I cant specify the Intersting traffic for both Tunnels. Are you talking about this entries on remote site?? Thanks..
Yes I am talking about remote site. Here is an example
access-list extended Crypto_10_Interesting
permit ip 172.20.100.0 0.0.0.255 192.168.12.0 0.0.0.255
access-list extended Crypto_20_Interesting
crypto map outside map 10 ipsec-isakmp
set peer ISPrAPublicIP
set transform-set XXX-XXX-XXX
match address Crypto_10_Interesting
match address Crypto_20_Interesting
Both tunnels are established to get to the 192.168.12.0 network, thats why the interesting traffic is destined for the same network. Also source is the same. Now how will router know which crypto map entry to trigger when the matched traffic arrives? It cant! Some scruffy tweaks can me made to that config like PNAT at remote site or defining different sources, but this is really not the best practise.
Brilliant.... Thanks and I appreciate. Can you send me any example if I use the load balancer device like linkproof then able to make Load Balancing between Links and Tunnels.
You are welcome :)
I have experienced Drytek and Cisco Linksys load balancers. But they again have the same problem I previously addressed. They can not understand the status of the link connected to far end device, and they run a service called NSD (Network Service Detection) (name depends on brand, but the function is same) to understand if the link is up or down. Long story short, you specify a destination address to ping (or some other services) in predefined intervals, if %x is lost, load balancer stops sending data over that link, untill ping becomes responsive. Much like ip sla monitors in cisco routers and firewalls.
In general, Load Balancer is deployed as ISP routers connected to LB and inside clients or switch to LB, but in your scenario, your inside router should be replaced with LB two ASAs connected to LB and inside switch to LB. NSDs can be set for pinging a device in remote site in intervals to understand if the tunel is up, and can be set to ping the gateway of your ISP router to detect internet connection failures.
If I go with the same details as you mentioned then will it be a best practise. Can you post a network diagrame with IP details so that it will be more easier to understand all entire things. Thanks
If i use dynamic routing protocols instead of static routed then the local site issue will be resolved.. Is it right????? But the prblem is on the remote location. Can you give me any other suggestion which well be use for best practise and cud be implement in the production. Thanks...
use GRE and do loadbalancing on the routers...
Best practise will be my very first advise with diagram attached. Since interesting traffic ACL will be based on the gre traffic created to different destinations, there wont be any issues.
you are using standalone ASAs,
you cannot loadbalance through them because of asymmetric routing.
session goes through one ASA and return traffic goes though another.
This contradict with a statful inspection.
In this case you must use contexts and ASR-group on ASAs
