Looking for solution to fix Etherleak for CISCO Router RV215
Lionel338
To all the experts in this forum,
I had did a VAPT scan via Nessus. There is a vulnerability finding (V8: Multiple Ethernet Driver Frame Padding Information
Disclosure (Etherleak)) detected for CISCO router RV215.
Would like to consult and check with you guys if any expert in this community has a solution to fix this  'Etherleak' in CISCO router RV215. Appreciate your kind assistance for the advice.
Thank you in advance.
balaji.bandi
what firmware running on the device, check any latest firmware available and upgrade to fix any security vul.
check below guide line CVE :
https://www.cisco.com/c/en/us/support/docs/csa/cisco-sa-sb-mult-vuln-CbVp4SUR.html
BB
Lionel338
Hi balaji.bandi,
I had upgraded the firmware to its latest version 1.3.1.7 and did a VAPT scan via Nessus for verification. It ended up with 1 crtitical, 2 high, 11 medium and 3 low vulnerabilities.
a. 1 no. of critical >> 20007 - SSL Version 2 and 3 Protocol Detection
b. 2 nos. of high>> 42873 - SSL Medium Strength Cipher Suites Supported (SWEET32)
c. 11 nos. of medium>> 51192 - SSL Certificate Cannot Be Trusted X 2; 65821 - SSL RC4 Cipher Suites Supported (Bar Mitzvah) X 2; 57582 - SSL Self-Signed Certificate X 2; 26928 - SSL Weak Cipher Suites Supported X 2; 104743 - TLS Version 1.0 Protocol Detection; 157288 - TLS Version 1.1 Deprecated Protocol X 2
d. 3 nos. of low>> 11197 - Multiple Ethernet Driver Frame Padding Information Disclosure (Etherleak); 69551 - SSL Certificate Chain Contains RSA Keys Less Than 2048 bits X 2
Wondering if there is/are other solutions you can offer to get all these resolved for RV215W.
Thanks in advance.
it looks this is end of software maintenance and almost end of hw/tac support in a few months.. so Cisco may not fix these..
I dont see in the admin guide a way to change the TLS version etc.. my suggestion is to allow management only from specific ip address, so limiting the exposure... using the "remote management" section.. i dont think there are any other features that use the http/https other than remote management..
