mail problem after pix model swap
fearon-j
Community Member
HI,
I swapped out a 515 running 6.0 (1) and replaced it with a 506 running 6.1 (4).
I copied over the config ( cut and paste) and everything copied over ok. Now I cannot send or receive email, but www access is ok. When i put the 515 back in everything works ok. i am only using 2 interfaces .Anyone got any ideas ??
amendez
Community Member
I had the same problem and I fixed with the following command:
no fixup protocol smtp 25
