01-16-2020 12:46 AM - edited 02-21-2020 09:50 AM
I'm trying to understand the different modes to access FDM of a FTD 6.5 failover cluster running on two ISA 3000 devices:
Which is not working is:
I need your help:
How can I connect to both nodes (e.g. for updates) without wiring the management port?
Any help is appreciated!
01-17-2020 01:30 AM - edited 01-17-2020 01:30 AM
When making any configuration changes on an FTD HA pair (including upgrades or patches) you need only log into the Active unit.
In the case of upgrades, I believe you need to log into the management interface on the secondary unit (thus it must be wired).
01-17-2020 05:49 AM
Thanks for your reply. What I don't understand yet is how this fits together with the documentation:
Quote: "... One way to configure Management/Diagnostic is to not wire the physical port to a network. Instead, configure the Management IP address only, and configure it to use the data interfaces as the gateway for obtaining updates from the internet. ..."
