Management Access to FDM of FTD 6.5 HA nodes running on ISA 3000
uhei
Beginner
Beginner
I'm trying to understand the different modes to access FDM of a FTD 6.5 failover cluster running on two ISA 3000 devices:
  • I can access the primary IP of any data-interface as long as I have enabled access on this interface and the packets for this connection reach the FTD on the specific data-interface
  • I can not access the primary IP of data-interface A when the connection comes in on data-interface B
  • I can connect to the management IP when I have a cable connected to the management port and the management interface is configured to use a dedicated gateway
Which is not working is:
  • Connect to a secondary IP (and thus to the standby node) of any data-interface even access to this data-interface is enabled
  • Connecting to the management IP when there is no cable connected to the management port but gateway is configured to use data-interfaces. This applies for both nodes (active and standby).
I need your help:
How can I connect to both nodes (e.g. for updates) without wiring the management port?
Any help is appreciated!
Marvin Rhoads
VIP Community Legend VIP Community Legend
When making any configuration changes on an FTD HA pair (including upgrades or patches) you need only log into the Active unit.
In the case of upgrades, I believe you need to log into the management interface on the secondary unit (thus it must be wired).
https://www.cisco.com/c/en/us/td/docs/security/firepower/650/fdm/fptd-fdm-config-guide-650/fptd-fdm-ha.html#task_AE850BD023684725BBA13AEC03BFE1DF
@Marvin Rhoads
Thanks for your reply. What I don't understand yet is how this fits together with the documentation:
https://www.cisco.com/c/en/us/td/docs/security/firepower/650/fdm/fptd-fdm-config-guide-650/fptd-fdm-interfaces.html#concept_EB3DE1BBDB9547EC8866365C7BC11792
Quote: "... One way to configure Management/Diagnostic is to not wire the physical port to a network. Instead, configure the Management IP address only, and configure it to use the data interfaces as the gateway for obtaining updates from the internet. ..."
Marvin Rhoads
You MIGHT be able to get it to work that way but it's more confusing since you will need to log into the primary IP address you've enabled for management (meaning on the active unit), perform the necessary tasks, change which unit is active, perform tasks on the other unit, etc.
In my experience it's easier to just have the management interfaces connected with unique always reachable addresses.
Recognize Your Peers
