Management interface for Failover
parvezahmad90
Please let me know Can we configured manangemet interface for lan based and statefull failover in ASA 5540 (Running 9.1 version).
Current Configuration for the interface is below.
interface Management0/0
management-only
nameif management
security-level 100
no ip address
I will create two subinterface of management for lan and statefull failover.
Will connect direct to another interface of secondary ASA.
Please let me know this solution will work.
Jouni Forss
I dont think you need to configure any subinterfaces for this
You could remove the "management-only" and "nameif" and "security-level 100" configurations from the interface. Though I think the "failover" configurations might remove these on their own.
You could use
failover
failover lan unit primary
failover lan interface failover Management0/0
failover key
failover link failover Management0/0
failover interface ip failover x.x.x.x 255.255.255.252 standby y.y.y.y
failover
failover lan unit secondary
failover key
- Jouni
Thanks a lot.
