Maximum threshold values CISCO ASA
Luis Carranza
Hi:
I hope you're doing fine, and happy new year by the way. For this case I need your help because we need to know what are the maximum threshold values for a CISCO ASA i mean for example if I had an ASA at 40 % of memory that could be a problem? or at what level we can consider it a problem.
I googling but I only found this:
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/product_data_sheet0900aecd802930c5.html
but in that document I only found the maximum values for VPN Connections, Concurrent connections, Maximum Firewall and IPS Throughput
Regards.
Luis Carranza
vilaxmi
Here is a document which compares various h/w models of ASA series and will answer most of your questions:
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
Also, for most ASA platforms, 40% is not bad, per CPU usage.
Vijaya
