Monitor Physical Interfaces for Failover -Portchannel in multi context
adamgerber
Hi -
We have a multi context firewall with portchannel subinterfaces.
Is there a way to failover monitor the individual physical ethernets bundled into the portchannel?
So if one of the physical Ethernet links in the port-channel goes down, we want the firewall (all contexts) to fail over to the secondary firewall.
KR,
Adam
balaji.bandi
you have system/managment  context access you can monitor that.
best we monitor switch side where they connected.
Monitor : i take it for utlisation -  not failover monitor right ?
BB
Hi  - apologies if I was not clear. This is for failover monitoring. So if one of the physical Ethernet links in the port-channel goes down, we want the firewall to fail over to the secondary firewall.
The advantage of the port-channel is for the high availability,
take an example, if the port channel has 4 ports, even if 1 link goes down rest 3 work as expected.
for the sub-interface will not have that visibility. and work as expected.
until you context resource physically allocated and used in that context, you will not see a physical interface in the context at all.
good practice I have seen in the deployment is always monitor allocated interface (in your case sub interface to fail over)
Hope that helps you.
BB
