Nat inside to outside, IP not in same subnet as outside IP
NathFoley11
I already posted this but cant seem to find the post now, so re-posting.
We have 10 IP's being NAT'd, all working ok.  I need a servers outbound source address to be translated to an IP that is not in the same subnet as the outside IP:
Outside IP = 193.xxx.xxx.99/23
Translated IP = 195.xxx.xxx.64/24
I have created the NAT rule to translate traffic source address from 192.168.2.55 to 195.xxx.xxx.64 packet trace shows it getting through, but this is not working in practice.  The host that I have set the NAT rule up for can no longer access wan.
Is this possible on an ASA?
Pranay Prasoon
Level 3
Level 3
This should work fine, provided the other Network is advertised by ISP and traffic comes back to ASA.
There were few restriction on some ASA software (8.4.3) though, rest most of the version works fine with "arp permit-nonconnected" starting from 8.4.5.
On 8.2 you don't need this command, it simply works fine.
Thanks.
Pranay Prasoon
Level 3
Level 3
Thanks.
Excellent, I was missing the arp permit-nonconnected.
Thanks for your help, if anyone comes across this thread, there is a good explanation into the command arp permit-nonconnected here:
https://supportforums.cisco.com/discussion/11848306/arp-permit-nonconnected
Hozaifa Samad
It should work. I'd run capture on the outside and see if the packet is leaving the ASA and it's coming back or not. If it is, then it's ASA config within the NAT, and you need to look at proxy-arp parameter. If the packet doesn't come back, then it's maybe the router outside the ASA. You might need to take care of manual arp (ASA outside MAC and the new translate IP) and the routing to the new subnet back to ASA outside IP.
