NAT using different IP range than on outside interface
clark.d
Level 3
Level 3
I have a need to use another class C subnet for outbound NAT purposes, but this new range isn't bound to the outside interface. Is this possible?
Outside interface IP: 1.1.1.1/24
Inside interfac ip: 10.1.1.x/24
New block: 192.168.1.0/24
New inside hosts needing nat on new range: 10.14.1.x/24
So basically I want to use a range of ip's not bound to and interface to use as the PAT'd address when the packet leaves the ASA. What would this config look like?
Thx
hobbe
Level 11
Level 11
Yes it is possible (atleast with 8.2) but only for inbound connections, otherwise you would have a routing problem since it does not support policy based routing.
Just configure it as you would do a normal static but with the address from the other net and it will work just fine.
do not forget to allow the traffic in an ACL
Good luck
