NATing "Reverse Path Failure" problem - help required
Cormac Champion
Level 5
Level 5
Hi all,
I'm new to ASA's and I have a NATing issue which I'm unable to resolve.  I'm trying to allow external access through my ASA to a Web Server.
I've used the Packet Tracer in the ASDM and it's recording the following in the Monitoring log
Asymmetric NAT rules matched for forward and reverse flows; Connection for tcp src MY-ISP:xx.xx.xx.xx/1065 dst INSIDE:10.10.10.101/443 denied due to NAT reverse path failure
The NAT Rule I have added is as follows
nat (INSIDE,MY-ISP) source static obj-Web_Server interface service any REMOTE-HTTPS
Where
object network obj-WEB_Server
host 10.10.10.101
object service REMOTE-HTTPS
service tcp source eq https
My ISP Connection is presented as 192.168.1.17.  The ISP forwards all ports from their router to mine.  I have a 0.0.0.0 0.0.0.0 via 192.168.1.1 for my ISP connection
From what I have read, it seems I need to add a NoNat ACL somewhere, but with the ASDM, I'm not sure as to where this should be added, and in what form.
bhargavdesai
You need service https https in the below statement.
And make sure you have configured ACL on the interface MY-ISP to allow access in for your web server.
