Need Best practice guide for Putting Firewall or Router on Edge?
Learnercisco
Hi Teck Guys.
Please share a cisco validate design for putting FPS 2130 or Router ASR1K on edge. i have attached my block diagram. suggest the validate design. Thanks All.
7 Replies 7
balaji.bandi
A best possible way is :
Access Switch ( where users connect) --- Core ----FW---ASR----Internet
A couple of questions :
1.  what is mean by Access switch - where the users PC or device connected, in this case above is bet example.
2. or if that is WAN Aggregation switch to connect, then your design should be ok.
BB
Thanks BB for your Valueable reply,
My design is related to the following:
Access---Distributiion----Core----FW----WANaggregSwitch----ASR1K- Internet.
I suppose your  reply  is related the above design. Please Confirm.
2.  if that is WAN Aggregation switch to connect, then your design should be ok.
Access---Distribution----Core----FW----WANaggregSwitch----ASR1K- Internet
This make sense.
But  WANaggregSwitch - this switch only connect to internet or your satellite sites or Branch office?
BB
Hi BB,
Thanks for reply,
we could use this WAN Agg Switch between Firewall and Router for Internet traffic.we have 3 remote branches in campus network, shall directly connect to ISR1K via Fiber Optic Link or we can connect to WAN Aggregate Switch.  i prefer to connect to ASR1K for Routing in one place on upstream. Thanks
If the branch office point to point to link
i prefer to take inside the network, but if you do not have any other device dedicated to WAN Aggregation inside network.
I will use ASR and make necessary FW rules for the device to access internal resources.
BB
Seb Rupik
Hi there,
You may want to take a look at the CVD guide for the internet edge:
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/Oct2015/Internet_Edge_Design_Oct2015.pdf
cheers,
Seb.
Thanks SR for the valueable reply.
