Need fluid traffic between two same security level interfaces
Eduardo Guerra
Level 3
Level 3
Dear Sirs I am configuring an ASA5510 before implementing it on my network. I have 1 ISP for internet connected to Outside Interface, a DMZ Interfaces and 2 inside interfaces. One of these inside interfaces is Outside1 will be connected to a router that will have Fiber and Antenas for communicating with our small offices. I need fluid traffic between Inside an Outside1. I tried using some advices but still not working. Here's my configuration. Can you help me?
: Saved
ASA Version 8.2(1)
hostname ASAFCHFW
domain-name farmaciachavez.com.bo
enable password 6Jfo5anznhoG00fM encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
nameif Outside
security-level 0
ip address X.X.X.X y.y.y.y
interface Ethernet0/1
nameif Outside1
security-level 100
ip address 192.168.2.2 255.255.255.0
interface Ethernet0/2
nameif DMZ
security-level 10
ip address 172.16.31.1 255.255.255.0
interface Ethernet0/3
nameif Inside
security-level 100
ip address 192.168.100.1 255.255.255.0
interface Management0/0
nameif management
security-level 100
management-only
boot system disk0:/asa821-k8.bin
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list dmz_in extended permit ip any any
access-list dmz_in extended permit icmp any any
access-list Inside extended permit ip any any
access-list Inside extended permit icmp any any
access-list 100 extended permit tcp any host x.x.x..163 eq smtp
access-list 100 extended permit udp any host x.x.x.163 eq domain
access-list 100 extended permit tcp any host x.x.x.163 eq https
access-list 100 extended permit tcp any host x.x.x.163 eq www
pager lines 24
logging enable
logging asdm informational
mtu Outside 1500
mtu Outside1 1500
mtu DMZ 1500
mtu Inside 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit 192.168.100.0 255.255.255.0 Outside1
icmp permit 192.168.2.0 255.255.255.0 Inside
asdm image disk0:/asdm-647.bin
asdm history enable
arp timeout 14400
global (Outside) 101 interface
nat (DMZ) 101 0.0.0.0 0.0.0.0
nat (Inside) 101 0.0.0.0 0.0.0.0
static (Inside,DMZ) 192.168.100.0 192.168.100.0 netmask 255.255.255.0
static (DMZ,Outside) x.x.x.163 172.16.31.0 netmask 255.255.255.255
static (DMZ,Inside) 172.16.31.0 172.16.31.0 netmask 255.255.255.0
access-group 100 in interface Outside
access-group dmz_in in interface DMZ
route Outside 0.0.0.0 0.0.0.0 x.x.x.161 1
route Outside1 172.1.1.0 255.255.255.0 192.168.2.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
http 192.168.100.0 255.255.255.0 Inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:b5e4725e47eea02221510b282e9e5843
: end
Thanks in advanced
Eduardo Guerra
Can you post the results of this command?
packet-tracer input inside tcp 192.168.100.5 9823 192.168.2.10 80 detail
and
packet-tracer input Outside1 tcp 192.168.2.10 9823 192.168.100.5 80 detail
25 Replies 25
Collin Clark
So is there no communications from inside to outside1?
Eduardo Guerra
Level 3
Level 3
Yes, there is no communication. I tried pinging from a computer connected to Inside to computer connected to Outside1 and viceversa, also i tried to access shared resources from each computer with negative results
EG
Try to use the following command"
- Prateek Verma
and
Here are the results:
packet-tracer input inside tcp 192.168.100.5 9823 192.168.2.10 80 detail     (Last 2 Phases)
Phase: 5
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
  match ip Inside 192.168.100.0 255.255.255.0 DMZ any
    static translation to 192.168.100.0
    translate_hits = 0, untranslate_hits = 471
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xab9355d0, priority=5, domain=host, deny=false
        hits=1611, user_data=0xab934f90, cs_id=0x0, reverse, flags=0x0, protocol
=0
        src ip=192.168.100.0, mask=255.255.255.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Phase: 6
Type: NAT
Subtype:
Result: DROP
Config:
  match ip Inside any Outside1 any
    dynamic translation to pool 101 (No matching global)
    translate_hits = 94, untranslate_hits = 0
in  id=0xab9309e8, priority=1, domain=nat, deny=false
        hits=93, user_data=0xabeffa80, cs_id=0x0, flags=0x0, protocol=0
        src ip=0.0.0.0, mask=0.0.0.0, port=0
Result:
input-interface: Inside
input-status: up
input-line-status: up
output-interface: Outside1
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
packet-tracer input Outside1 tcp 192.168.2.10 9823 192.168.100.5 80 detail      (Last 2 Phases)
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xab7f6198, priority=0, domain=permit-ip-option, deny=true
        hits=776, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 6
Type: NAT
Subtype:
Result: DROP
Config:
nat (Outside1) 101 0.0.0.0 0.0.0.0
  match ip Outside1 any Inside any
    translate_hits = 1, untranslate_hits = 0
in  id=0xac0c13f8, priority=1, domain=nat, deny=false
        hits=0, user_data=0xac0c1338, cs_id=0x0, flags=0x0, protocol=0
Result:
input-interface: Outside1
input-status: up
output-interface: Inside
output-status: up
Action: drop
Also i added this command:
EG
Try to put in following commands:
static (Inside,outside1) 192.168.100.0 192.168.100.0 netmask 255.255.255.0
static (outside1,Inside) 192.168.2.0 192.168.2.0 netmask 255.255.255.0
- Prateek Verma
Dear Prateek, configurationo is like this and i can connect between interfaces but i cant access to network 172.1.1.0 that is connected to another router that is connected to interface Outside1. Any suggestion for this?
ASA Version 8.2(1)
hostname ASAFCHFW
names
nameif Outside
security-level 0
ip address 200.87.200.162 255.255.255.248
nameif Outside1
security-level 100
ip address 192.168.2.1 255.255.255.0
nameif DMZ
security-level 10
nameif Inside
security-level 100
ip address 192.168.0.1 255.255.255.0
nameif management
security-level 100
management-only
ftp mode passive
access-list 100 extended permit tcp any host 200.87.226.163 eq smtp
access-list 100 extended permit udp any host 200.87.226.163 eq domain
access-list 100 extended permit tcp any host 200.87.226.163 eq https
access-list 100 extended permit tcp any host 200.87.226.163 eq www
pager lines 24
logging enable
mtu Outside 1500
mtu Outside1 1500
mtu DMZ 1500
mtu Inside 1500
mtu management 1500
icmp permit 192.168.0.0 255.255.255.0 Outside1
icmp permit 192.168.2.0 255.255.255.0 Outside1
icmp permit 192.168.0.0 255.255.255.0 Inside
asdm history enable
arp timeout 14400
static (DMZ,Outside) 200.87.200.163 172.16.31.0 netmask 255.255.255.255
static (Outside1,Inside) 192.168.2.0 192.168.2.0 netmask 255.255.255.0
static (Inside,DMZ) 192.168.0.0 192.168.0.0 netmask 255.255.255.0
static (Inside,Outside1) 192.168.0.0 192.168.0.0 netmask 255.255.255.0
route Outside 0.0.0.0 0.0.0.0 200.87.200.161 1
route Outside1 172.1.1.0 255.255.255.0 192.168.2.2 1
http server enable
http 192.168.0.0 255.255.255.0 Inside
telnet 192.168.0.0 255.255.255.0 Inside
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
Cryptochecksum:6dfac383495fa18bde8783c7d47c3d81
: end
Thanks in advanced
EG
What happens if you increase the routing distance for the default route, e.g.
  route Outside 0.0.0.0 0.0.0.0 200.87.200.161 20
-- Jim Leinweber, WI State Lab of Hygiene
Default route is for internet use. Another static route is for connecting headquater with another offices
EG
I've modified route like James told but no changes. I run a this packet tracer and result is this
Packet Tracer:
packet-tracer input inside tcp 192.168.0.5 9823 172.1.1.10 80 detail
Result:
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   172.1.1.0       255.255.255.0   Outside1
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in  id=0xab8755c8, priority=2, domain=permit, deny=false
        hits=175, user_data=0x0, cs_id=0x0, flags=0x3000, protocol=0
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xab877570, priority=0, domain=permit-ip-option, deny=true
        hits=299, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Config:
  match ip Inside 192.168.0.0 255.255.255.0 Outside1 any
    static translation to 192.168.0.0
    translate_hits = 179, untranslate_hits = 18292
Static translate 192.168.0.0/0 to 192.168.0.0/0 using netmask 255.255.255.0
in  id=0xab94c948, priority=5, domain=nat, deny=false
        hits=175, user_data=0xab94c0a0, cs_id=0x0, flags=0x0, protocol=0
        src ip=192.168.0.0, mask=255.255.255.0, port=0
Phase: 6
Type: NAT
Result: ALLOW
Config:
  match ip Inside 192.168.0.0 255.255.255.0 DMZ any
    translate_hits = 0, untranslate_hits = 11
in  id=0xab811c80, priority=5, domain=host, deny=false
        hits=18742, user_data=0xab8d1270, cs_id=0x0, reverse, flags=0x0, protoco
l=0
Phase: 7
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
    translate_hits = 309, untranslate_hits = 0
out id=0xab93f558, priority=1, domain=nat-reverse, deny=false
        hits=74, user_data=0xab93f2e8, cs_id=0x0, flags=0x0, protocol=0
Result:
input-status: up
output-status: up
Action: drop
Any ideas for solving this route issue?
EG
There is no NAT so it's failing.
Phase: 7
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
Have you tried Prateek's commands?
Prateek's commands are one way to fix it.
You could also try-
global (Inside) 102 interface
nat (Outside1) 102 0 0
Dear Collin, do these lines:
will not restrict traffic to the internet by interface Outside?
EG
Those lines will nat traffic from Outside1 to the Inside using the IP assigned to the Inside interface.
Collin, Here's my network diagram. I need to use static routes from Lan to 172.1.x.x to communicate other offices with headquater LAN (I need NAT no PAT as you suggested answer before). Also i need to communicate branch offices with email server. Actually the service router i am using to connect branch offices is Cisco RV016 but in the near future it will be ISR G2 Cisco 892
If you need some more explanation to solve routing issue, please tell. also here's the up to date configuration
ASA Version 8.2(1)
hostname ASAFCHFW
names
nameif Outside
security-level 0
ip address x.x.x.162 255.255.255.248
nameif Outside1
security-level 100
nameif DMZ
security-level 10
nameif Inside
security-level 100
nameif management
security-level 100
management-only
ftp mode passive
access-list 100 extended permit tcp any host x.x.x.163 eq smtp
pager lines 24
logging enable
mtu Outside 1500
mtu Outside1 1500
mtu DMZ 1500
mtu Inside 1500
mtu management 1500
asdm history enable
arp timeout 14400
route Outside 0.0.0.0 0.0.0.0 x.x.x.161 20
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
Cryptochecksum:3235bd0aa15e755b360cd2fb30b227ef
: end
EG
