need help, devices not shown on csm
Lother99
Hi their
I m using cisco security manger 4.7 every thing was normal but now i can't find all my firewalls on the device liste, even though i can see the events detected by the disappeared FW,
Also adding a FW to the device liste, it disappears  directly
Any suggestion p
Hi.
Did you find the solution for your problem?
Regards, Aleš Krek.
