06-10-2013 11:06 PM - edited 03-11-2019 06:55 PM
hi in IPv4 everthing was working fine. i could access from outside to dmz but after i moved to IPv6 as there is no nat needed, i applied the acl's but dont know where i'm going wrong. I need access from outside to dmz web server. here's my config pls reply asap... plss. I just want only http service to be enabled as only webserver access i need.
show run
: Saved
ASA Version 8.0(4)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
no ip address
ipv6 address fc04::2/64
ipv6 enable
interface Ethernet0/1
nameif inside
security-level 100
ipv6 address fc06::1/64
ipv6 enable
interface Ethernet0/2
nameif dmz
security-level 70
no ip address
ipv6 address fc05::1/64
ipv6 enable
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
object-group service DM_INLINE_TCP_1 tcp
port-object eq www
port-object eq https
object-group service DM_INLINE_TCP_2 tcp
port-object eq www
object-group service DM_INLINE_TCP_3 tcp
port-object eq www
pager lines 24
mtu inside 1500
mtu dmz 1500
mtu outside 1500
ipv6 route outside ::/0 fc04::1
ipv6 access-list inside_access_ipv6_in permit ip any any
ipv6 access-list inside_access_ipv6_in permit tcp any fc05::/64 object-group DM_
INLINE_TCP_2
ipv6 access-list dmz_access_ipv6_in permit ip any any
ipv6 access-list dmz_access_ipv6_in permit tcp any fc05::/64 object-group DM_INL
INE_TCP_1
ipv6 access-list outside_access_ipv6_in permit ip any any
ipv6 access-list outside_access_ipv6_in permit tcp any fc05::/64 object-group DM
_INLINE_TCP_3
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-711.bin
no asdm history enable
arp timeout 14400
access-group inside_access_ipv6_in in interface inside
access-group dmz_access_ipv6_in in interface dmz
access-group outside_access_ipv6_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
prompt hostname context
Cryptochecksum:00000000000000000000000000000000
: end
06-11-2013 07:50 AM
Hello Suhail,
From which IPv6 address are you trying to access the Web-dmz server,
I do not see any routes, what is the IPv6 address of the DMZ server?
06-11-2013 07:58 AM
dmz server ip address is fc05::2/64
i'm trying to access from a pc which is connected to a router and inturn which is connnected to the router of firewall
fc01::1 is the ip add of the machine from which i'm trying to connect..
routing is okay i gues because from pc to outside interface of asa fc04::2 i'm able to ping. and from the asa console i'm able to ping every device, pc.. the problem is from outside of asa is not pinging to inside of dmz and vice versa so no transmission is taking placing between them
06-11-2013 08:01 AM
Hello Suhail,
Yeah, I missed the IPv6 route, now I see it,
Can you create captures to match the traffic and apply it to both interfaces?
Right now looks like the ASA setup is good so the captures will tell us where the issue is,
06-11-2013 07:50 AM
If you put permit ip any any as the first line in an access-lists, then pretty much all packets are going to be allowed through. You can see which lines in your ACL's are matching by doing either:
show access-list
to get the hit counts, or something like
packet-tracer input outside tcp fc04::3 50000 fc05::3 80 detail
to see what would happen to a particular flow. If you take the "permit ip any any" line out, the tcp line will become effective.
Note that in version 9, v4 and v6 access lists were unified, so the syntax will change some when you upgrade.
Since you are using ULA addresses (fc00::/7) rather than global scope addresses (2000::/3), I assume this is in a test lab. Everyone should have IPv6 in their test lab, so congratulations.
-- Jim Leinweber, WI State Lab of Hygiene
