Need Help for configuring Floating static route in My ASA.
roopesh.n
Hi All,
I need your support for doing a floating static route in My ASA.
I have tried this last time but i was not able to make it. But this time i have to Finish it.
Please find our network Diagram and configuration of ASA
route outside 0.0.0.0 0.0.0.0 6.6.6.6 1 track 1
route rOutside 0.0.0.0 0.0.0.0 3.3.3.3 10
route inside 10.10.4.0 255.255.255.0 10.10.3.1 1
route inside 10.10.8.0 255.255.255.0 10.10.3.1 1
route inside 10.10.9.0 255.255.255.0 10.10.3.1 1
route inside 10.10.15.0 255.255.255.0 10.10.3.1 1
route rOutside x.x.x.x 255.255.255.255 5.5.5.5 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.10.3.77 255.255.255.255 inside
http 10.10.8.157 255.255.255.255 inside
http 10.10.3.59 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sla monitor 123
type echo protocol ipIcmpEcho 8.8.8.8 interface outside
num-packets 3
frequency 10
sla monitor schedule 123 life forever start-time now
crypto ipsec transform-set cpa esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map vpn_cpa 1 match address acl_cpavpn
crypto map vpn_cpa 1 set peer a.a.a.a
crypto map vpn_cpa 1 set transform-set abc
crypto map vpn_cpa 1 set security-association lifetime seconds 3600
crypto map vpn_cpa interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
track 1 rtr 123 reachability
telnet 10.10.3.77 255.255.255.255 inside
telnet 10.10.8.157 255.255.255.255 inside
telnet 10.10.3.61 255.255.255.255 inside
telnet timeout 500
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 10.10.3.14
webvpn
tunnel-group .a.a.a.a ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
inspect sip
  inspect xdmcp
service-policy global_policy global
smtp-server 10.10.5.11
prompt hostname context
Cryptochecksum:eea6e7b6efe5d1a180439658c3912942
: end
i think half of the configuration stil there in the ASA.
Diagram.
Roopesh
6 Replies 6
Hi Roopesh,
Checking I see the same route twice:
On the other hand, what exactly is not working?
Thanks.
Portu
Please rate any helpful posts.
Hi Portu,
Thanks for the replay
I am really forget raise my issue.
Here it is As we sow in the diagram we have two ISP. So we have pointed our default route to ISP1(6.6.6.6 Primary ISP).and it is working fine .and we have secondary Link to ISP2 we need to configure this as our backup link. Once the ISP1 fails the traffic should be routed to ISP2 automatically. i think i can accomplish this by doing IP SLA and Floating route but  I am not sure about the complete configuration and I am new to ASA.
Roopesh
Roopesh,
Please make the following change:
no route outside 0.0.0.0 0.0.0.0 6.6.6.6 1
Are planning to NAT any traffic on this ASA?
Thanks.
Portu.
Portu,
We have Some ststic NAt for our DMZ server and a gloabal nat for all.
global (outside) 101 interface
nat (inside) 101 0.0.0.0 0.0.0.0
I have removed the route  route outside 0.0.0.0 0.0.0.0 6.6.6.6 1
Roopesh
You have missed the last command in your configuration, Please check it again
route ISP1  0.0.0.0 0.0.0.0 6.6.6.6 track 1
route ISP2   0.0.0.0 0.0.0.0 3.3.3.3
sla monitor 10
type echo protocol ipIcmpEcho 8.8.8.8 interface ISP1
num-packets 3
frequency 10
You can do NAT in same way, here the logical name of the interface will be different.
Share the result
Hi Saurabh,
I have already given the track.
Please refer my first configuration.Can you explain little more about NAT ing part for this
Roopesh
