Need help & Guidence,
amit03tiwari1
I am having some problem in installing & configuring CISCO PIX 501 firewall, console cable came with it is having serial port, wheare as systems coming now a days & the one with me does not have any serial port, How i could access command-in-line for configuration, could anyone help, please help me out.. waiting for your response,
prateeve
Hi Amit,
You have to get serial to USB converted to access it.
- Prateek Verma
i have tried that, but when i was trying to access asdm/pdm through 198.168.1.1 it connects me to router insted of firewall, & when i use ping command it dosent show any prob, next time i switched off router & directly connect firewall to system, it fails to show any ping report, it fails to ping on same address 192.168.1.1, /... what should i do.. ??
