Need Help on one Firewall Question
jaskamboj
Hi All,
I am using cisco asa in my environment and which is connected to l2. One server and one router is also connected to L2. Now i want to access port 80 on my server from outside.
How its possible if the server gateway is routers ip and i don't want to add static route in router or server towards the firewall. Nat and access List is done on firewall. what else i can do on firewall to access port 80 of my server from outside. Dont want to change anything on router/server.
Below is the IP detail
1. Firewall inside 192.168.1.1 & Outside 1.1.1.1
2. Router IP - 192.168.1.2
3. Server IP - 192.168.1.3 & GW - 192.168.1.2
18 Replies 18
Hi Jouni,
Have tried with earlier configuration but no luck..
If you have those old NAT format configurations on your PIX firewall then I would like to see the output of a "packet-tracer" command simulating a connection coming for your webserver
It would be something like this
packet-tracer input outside tcp 123.123.123.123 12345 80
This should tell us what NAT rules are matched on the firewall for such a connection. Just enter your public IP address used for the Web servers NAT command.
- Jouni
Please find the bleow report.
packet-tracer input outside tcp 1.1.1.2 www 1.1.1.1  www
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
static (inside,outside) tcp interface www 192.168.1.3 www netmask 255.255.255.255
  match tcp inside host 192.168.1.3 eq 80 outside any
    static translation to 1.1.1.1/80
    translate_hits = 0, untranslate_hits = 10
NAT divert to egress interface inside
Untranslate 1.1.1.1/80 to 192.168.1.3/80 using netmask 255.255.255.255
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group WEBSERVER in interface outside
access-list WEBSERVER extended permit tcp any host 1.1.1.1 eq www
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 6
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 10, packet dispatched to next module
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
Only situation where I managed to get this working was when I configured
global (inside) 100 interface
nat (outside) 100 0.0.0.0 0.0.0.0 outside
I tried to configure Dynamic Policy PAT on the "outside" -> "inside" but it didnt seem to work.
- Jouni
