Need Help - Pix 515 v6.3(5) outbound nat using Static ?
dclee
I have a unique situation where I have the following inside network being translated to an outside public IP
so nat (inside) 1 192.168.10.0 255.255.255.0
     global (outside) 1 207.x.x.3
This works great, however I need one of those inside hosts (192.168.10.27)  to be translated to a unique outside ip 207.x.x.4
Can I simply do this ?
Nat (inside) 2 192.168.10.27
global (outside) 2 207.x.x.4
Will the translation table not hit the 1st Nat 1 statement and pass thru on .3, or will it actually trickle down to Nat 2 statement and match on .4
Cheers
Dave
That is what the static translations are for:
static(inside,outside) 207.x.x.4 192.168.10.27 netmask 255.255.255.255
These have a higher priority then the dynamit translations with nat and global.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
nkarthikeyan
Level 7
Level 7
Hi dave,
You can use the static NAT to achieve the requirement which you have specified.
static (inside,outside) 207.x.x.4 192.168.10.27 netmask 255.255.255.255
You can refer the below guide for more information on the static NAT.
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/s.html#wp1026694
By
Karthik
Please do rate if the given information helps.
Jennifer Halim
To answer your question, yes, you can configure the more specific NAT statement as you have stated:
as the more specific NAT statement will take precedence over the generic NAT statement.
Just have to make sure that you "clear xlate" after the new config.
Here is the NAT order of operation and in your case, point number 4 is what you are after:
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/cfgnat.html#wp1042696
Hope that helps.
