Need help please configuring my FirePower 1010
Hi all,
Need help configuring please with my FirePower 1010
below is what I have.when i type in web browser 192.168.1.1 nothing happens. Thanks
> show interface ip brief
Interface                  IP-Address      OK?           Method Status      Protocol
Internal-Data0/0           unassigned      YES           unset  up          up
Vlan1                      192.168.1.1     YES           manual up          up
Ethernet1/1                unassigned      YES           DHCP   down        down
Ethernet1/2                unassigned      YES           unset    up             up
Ethernet1/3                unassigned      YES           unset  down        down
Ethernet1/4                unassigned      YES           unset  down        down
Ethernet1/5                unassigned      YES           unset  down        down
Ethernet1/6                unassigned      YES           unset  down        down
Ethernet1/7                unassigned      YES           unset  down        down
Ethernet1/8                unassigned      YES           unset  down        down
Internal-Control1/1        unassigned      YES          unset  up           up
Internal-Data1/1           169.254.1.1     YES           unset  up          up
Internal-Data1/2           unassigned      YES           unset  up           up
Management1/1              unassigned      YES         unset  up          up
balaji.bandi
what version does FP ship with? I am sure latest one ship 6.5 (since i see the IP 192.168.1.1) - what interface is your PC connected to what is your PC IP address : (do not connect to Eth 1/1 which belongs to outside)
Look at the Quick start Guide :
inside—IP address (7.0 and later) 192.168.95.1; (pre-7.0) 192.168.1.1.
  • (6.5 and later) Hardware switch—Ethernet 1/2 through 1/8 belong to VLAN 1
https://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/fp1010/firepower-1010-gsg/ftd-fdm.html
BB
johnlloyd_13
Level 9
Level 9
hi,
there's a "special" cable patching you need to follow for FTD 6.4 and earlier and FTD 6.5 and above.
there's a factory reset button if you need to start all over.
see helpful link:
https://wannabecybersecurity.blogspot.com/2020/09/cisco-firepower-1010-initial.html
Good morning,
Thank you for your responses.
I was to get configure but not the way  I had the ASA 5506-X. With the FPR 1010 what through me off is the Vlan1.
what I want is to have the FPR1010 set up like the ASA which is i had 3 networks (home, Security, Guest) because on switch i have trunk 10,20,30 and that how my interface where set up on the in ASA
192.168.10.254, 192.168.20.254, 192.168.30.254
I have the configuration saved for the ASA so i thought copy and paste on the FPR1010 but wasn't the case ( or you guys have better idea) I am all ears!!
with ASA didnt have to worry about the VLAN's and where I struggle.
There is a way to delete it or that not an option??
below is my config on the FPR1010 right now.
PLEASE take a look at it
interface Vlan1
nameif inside
security-level 0
ip address 192.168.10.1 255.255.255.0
interface Ethernet1/1
no switchport
nameif outside
cts manual
propagate sgt preserve-untag
policy static sgt disabled trusted
security-level 0
ip address dhcp setroute
interface Ethernet1/2
switchport
interface Ethernet1/3
switchport
interface Ethernet1/4
switchport
interface Ethernet1/5
switchport
interface Ethernet1/6
switchport
interface Ethernet1/7
switchport
power inline auto
interface Ethernet1/8
switchport
power inline auto
interface Management1/1
management-only
nameif diagnostic
cts manual
security-level 0
no ip address
ftp mode passive
ngips conn-match vlan-id
dns domain-lookup any
dns server-group CiscoUmbrellaDNSServerGroup
name-server 208.67.222.222
name-server 208.67.220.220
dns-group CiscoUmbrellaDNSServerGroup
object network any-ipv4
subnet 0.0.0.0 0.0.0.0
object network any-ipv6
subnet ::/0
object-group service |acSvcg-268435457
service-object ip
access-list NGFW_ONBOX_ACL remark rule-id 268435457: ACCESS POLICY: NGFW_Access_Policy
access-list NGFW_ONBOX_ACL remark rule-id 268435457: L5 RULE: Inside_Outside_Rule
access-list NGFW_ONBOX_ACL advanced trust object-group |acSvcg-268435457 ifc inside any ifc outside any rule-id 268435457 event-log both
access-list NGFW_ONBOX_ACL remark rule-id 1: ACCESS POLICY: NGFW_Access_Policy
access-list NGFW_ONBOX_ACL remark rule-id 1: L5 RULE: DefaultActionRule
access-list NGFW_ONBOX_ACL advanced deny ip any any rule-id 1
pager lines 24
logging enable
logging timestamp
logging permit-hostdown
mtu inside 1500
mtu outside 1500
mtu diagnostic 1500
no failover
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
nat (inside,outside) source dynamic any-ipv4 interface
access-group NGFW_ONBOX_ACL global
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication login-history
http server enable
http 0.0.0.0 0.0.0.0 inside
http ::/0 inside
ip-client inside ipv6
ip-client inside
ip-client outside ipv6
ip-client outside
ip-client diagnostic ipv6
no snmp-server location
no snmp-server contact
sysopt connection tcpmss 0
no sysopt connection permit-vpn
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
crypto ikev2 policy 100
encryption des
integrity sha
group 14
prf sha
lifetime seconds 86400
crypto ikev1 policy 150
authentication rsa-sig
encryption des
hash sha
group 14
lifetime 86400
crypto ikev1 policy 160
authentication pre-share
encryption des
hash sha
group 14
lifetime 86400
telnet timeout 5
console timeout 0
dhcp-client client-id interface outside
dhcpd auto_config outside
dhcpd address 192.168.10.5-192.168.10.253 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol ssl-client
webvpn
anyconnect ssl dtls none
dynamic-access-policy-record DfltAccessPolicy
class-map inspection_default
match default-inspection-traffic
class-map class_snmp
match port udp eq 4161
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
no tcp-inspection
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
inspect icmp error
inspect snmp
class class_snmp
inspect snmp
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
app-agent heartbeat interval 1000 retry-count 3
snort preserve-connection
Cryptochecksum:c4792d09f7585b93096be4bccefa066f
: end
