Need Help regarding ASA 5510
zaheerpsg
Community Member
Hello all,
I am trying to configure my asa5510 in transparent mode, I am using two interfaces, 1 for inside and 1 for outside.
Everything seem to be working great, but the problem is i want to access asdm, which is not possible without ip address.
I have followed cisco documents regard BVI interfaces, but it looks like there is not BVI interface exist on my firewall. Moreover i am unable to configure and VLANs.
Can someone please help me out in this regard?
Pulkit Saxena
A sample configuration :
firewall transparent
interface Ethernet0/0
nameif outside
security-level 0
interface Ethernet0/1
nameif inside
security-level 100
exit
Now do basic ASDM configuration and we should be good.
Check this document :
http://www.cisco.com/c/en/us/support/docs/security/pix-500-series-security-appliances/97853-Transparent-firewall.html
Pulkit
Pulkit Saxena
nameif outside
security-level 0
nameif inside
security-level 100
exit
Pulkit
Thank you Pulkit, that was helpful.
