Need help with a couple of issues concerning an AIP-SSM
cdetirado
1. How can I see what software versoin the sensor is running.
2. How can I manually update the sensors image.
3. How can I see through the cli when the signatures were last updated.
4. How can I unblock traffic that is being blocked by the Sensor.
34 Replies 34
Carlos;
You will want to upgrade to 7.0(3)E4 using the file I mentioned
previously.
Scott
cdetirado
This is what is currently in the IPS sensors, will that file that you recommended upgraded both to the same level for the system image.
Host Certificate Valid from: 23-Jan-2010 to 24-Jan-2012
PRIMARY
fpk-asa-ss5520# sh ver
Application Partition:
Cisco Intrusion Prevention System, Version 6.2(2)E4
Host:
    Realm Keys          key1.0
Signature Definition:
    Signature Update    S480.0                   2010-03-24
OS Version:             2.4.30-IDS-smp-bigphys
Platform:               ASA-SSM-20
Serial Number:          JAF1310APGT
Licensed, expires:      28-May-2012 UTC
Sensor up-time is 20:55.
Using 1030475776 out of 2093604864 bytes of available memory (49% usage)
application-data is using 43.0M out of 166.8M bytes of available disk space (27% usage)
boot is using 40.2M out of 68.6M bytes of available disk space (62% usage)
MainApp          E-ECLIPSE_2009_SEP_14_13_21_6_2_1_119   (Ipsbuild)   2009-09-14T13:22:32-0500   Running
AnalysisEngine   EE-ECLIPSE_E4_2010_MAR_25_00_44_6_2_2   (Ipsbuild)   2010-03-25T00:46:02-0500   Running
CLI              E-ECLIPSE_2009_SEP_14_13_21_6_2_1_119   (Ipsbuild)   2009-09-14T13:22:32-0500
Upgrade History:
  IPS-K9-6.2-2-E4   03:18:06 UTC Thu Mar 25 2010
Recovery Partition Version 1.1 - 6.2(2)E4
SECONDARY
fpk-asa-ss5520-s# sh ver
Cisco Intrusion Prevention System, Version 7.0(2)E3
Host:
    Realm Keys          key1.0
    Signature Update    S478.0                   2010-03-15
    Virus Update        V1.4                     2007-03-02
Serial Number:          JAF1350BAGJ
Licensed, expires:      19-Apr-2013 UTC
Sensor up-time is 33 days.
Using 1044209664 out of 2093600768 bytes of available memory (49% usage)
system is using 17.4M out of 38.5M bytes of available disk space (45% usage)
application-data is using 45.3M out of 166.8M bytes of available disk space (29% usage)
boot is using 41.5M out of 68.6M bytes of available disk space (64% usage)
application-log is using 123.5M out of 513.0M bytes of available disk space (24% usage)
MainApp            B-BEAU_2009_OCT_15_08_07_7_0_1_111   (Ipsbuild)   2009-10-15T08:09:06-0500   Running
AnalysisEngine     B-BEAU_2009_OCT_15_08_07_7_0_1_111   (Ipsbuild)   2009-10-15T08:09:06-0500   Running
CollaborationApp   B-BEAU_2009_OCT_15_08_07_7_0_1_111   (Ipsbuild)   2009-10-15T08:09:06-0500   Running
CLI                B-BEAU_2009_OCT_15_08_07_7_0_1_111   (Ipsbuild)   2009-10-15T08:09:06-0500
Upgrade History:
* IPS-K9-7.0-2-E3           19:43:07 UTC Thu Oct 15 2009
  IPS-sig-S478-req-E3.pkg   17:50:18 UTC Mon Mar 22 2010
Recovery Partition Version 1.1 - 7.0(2)E3
Host Certificate Valid from: 20-Mar-2010 to 20-Mar-2012
fpk-asa-ss5520-s#
Yes, that file should successfully upgrade both AIP-SSMs to release
7.0(3)E4.
Scott
When I try to download file 7.0(3)E4 it says that
IPS-K9-7.0-3-E4.pkg
Release Date: 07/Jun/2010
IPS 7.0 Major Upgrade File (All Supported Platforms Except AIM-IPS and NME-IPS)
Size: 29869.43 KB  (30586294 bytes)
And I am upgrading an AIP-SSM-20 what is the file that I can use to
That is the correct file - you are upgrading an AIP-SSM not an AIM-IPS
(this module is for Cisco Integrated Services Routers).
Scott
