Need help with a rule..
mmorris11
Level 9
Level 9
I wrote a rule with the intent of it firing upon events originating only from public ip addresses AND only for yellow OR red severity levels. However this rule still fires on green severity events. Can any one see why from looking at the rule in the attached graphic?
Thank you,
Mike
edwakim
Hi Mike,
I hope you are doing fine.
I guess you are talking about MARS here.
Could you please attach the graphic?
Thank you.
Edward
Edward Kim
Edward,
Glad I checked this! Actually what happened is that posted this before attaching and discovered that you can't attach after the fact. The full post is here: http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=Intrusion%20Prevention%20Systems/IDS&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddde4e8
Check out this TAC case (this is about something else): SR 605613157 - CSMARS-rule building
It led to an enhancement request: CSCsi17878 - Rules should have 'NOT-FOLLOWED-BY' operator
-mike
