Need Help with Cisco Firepower 1120
qlee
Problem:
Firewall shows it is connected to the Internet, it can sees the gateway. But, we not getting any data through.
What We've Tried:
Set up static and dynamic NATs, both before and after Auto NAT rules.
Used various zone objects and policies (network, host, IP range zones).
DNS is set up with Cisco and OpenDNS, and they're working fine.
Ping and Tracert tests both failed, even when forcing DNS by naming websites.
A couple things to check and answer if you could:
  • How is the FTD managed? (FMC / FDM / ASA)
  • Is the internet terminated directly on the Firewall, I mean does the firewall have a public IP on the "outside" interface?
  • Is the default route configured?
  • If yes, are you able to ping the default gateway IP from the firewall?
  • Are you able to ping 8.8.8.8 from the firewall?
If you are able to ping the internet from the firewall then there is possibly an issue with configuration.  In this case start by running a packet-tracer on the inside interface (the interface where client traffic is entering the firewall) and paste the results here.
Would also be good if you post the configuration for the following (remember to remove any public IP or otherwise sensitive information):
  • Interface configuration
  • static / default route configuration
  • Relevant ACP policy configuration
  • NAT configuration
Please remember to select a correct answer and rate helpful posts
Thanks, Marius.
We found the problem. It seems you cannot use the object "any-ipv4" when selecting a network. We had to create an object called "inside-network" and use a specific IP range. It appears this is not documented anywhere. However, after we rebooted the firewall to ensure it comes back online, it dropped offline again, and we got kicked out of the wizard after inputting the external connection.
Now, we are unable to access FTD. We will reset and try again.
Now we can’t figure why the Firewall will stay up and online for a few hours then go down. It requires a full factory reset to get it back online.
Could you be more specific. What do you mean when you say "Firewall will stay up and online for a few hours then go down" ?
