need help with l2tp tunnel on asa
akomancisco
Used VPN wizard to configure tunnel
upon connect, I get past phase 1 and fail with all ipsec sa proposal foun un acceptable
Please help
tstanik
Level 5
Level 5
Use "show crypto ca cert" command to display information about your certificate, the certificate of the CA, and any Registration Authority (RA) certificates and check if they are proper. Use command "show crypto isakmp sa" to check status of IKE SAs.
