Novice problem with static NAT rule
Dr.Debate
I have a very basic configuration...
ASA 5505 running 9.2(3)
Firewall mode:  Routed
Inside network is 192.168.253.0/24 (ASA is 192.168.253.1)
Outside network is 1.1.1.32/29 (ASA is 1.1.1.34)
Web server is 192.168.253.70 and I want that NAT'd to 1.1.1.35 with only port 80 open
Proxy ARP is disabled on inside but enabled on outside
This isn't working and even the debugging log doesn't show a reason.  I've got very minimal experience configuring ASA devices and I'm thinking I must have missed something very simple.  Any ideas out there?  Below are the relevant parts of my configuration:
interface Vlan1
 nameif inside
 security-level 100
 ip address 192.168.253.1 255.255.255.0
interface Vlan2
 nameif outside
 security-level 0
 ip address 1.1.1.34 255.255.255.248
object network obj_any
 subnet 0.0.0.0 0.0.0.0
object network Cable-02
 host 1.1.1.35
object network Cable-Network
 subnet 1.1.1.32 255.255.255.248
object network Svr-HTTP
 host 192.168.253.70
object-group service wwwServiceGroup
 service-object tcp destination eq www
access-list outside_access_in extended permit object-group wwwServiceGroup any object Cable-02
no arp permit-nonconnected
 nat (inside,outside) dynamic interface
 nat (inside,outside) static Cable-02
nat (inside,outside) after-auto source dynamic any interface
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 1.1.1.33 1
sysopt noproxyarp inside
6 Replies 6
Jon Marshall
The main issue is you are referencing the public IP in your acl but with 8.3 onwards you use the private IP in your acl ie. replace Cable-02 with Svr-HTTP.
That should fix the problem.
In addition your NAT statements could be modified but you don't need to for it to work ie. you have used a static NAT statement where you could have used a static PAT for just port 80 as this is the only one you want to allow and you have two NAT entries to translate your internal user IPs.
Like I say the main problem is the acl so don't worry too much about the rest but here is a link to a really helpful document which covers all this and gives some recommendations as to what to use and where -
https://supportforums.cisco.com/document/132066/asa-nat-83-nat-operation-and-configuration-format-cli
Jon
Thank you for the quick response and the helpful information.  Unfortunately, this did not solve my problem.  Does this syntax look correct?
access-list outside_access_in extended permit object-group wwwServiceGroup any object Svr-HTTP
Is it possible I need to change the interface to inside?  That doesn't make sense to me but, again, novice.
You just caught me before logging off.
I must admit I never use that syntax ie. I usually do -
access-list outside_access_in permit tcp any object Svr-HTTP eq <port number>
although I'm not saying your syntax won't work.
You need the acl applied to the outside interface so you have it correctly applied.
Like I say I have to go now but if the above makes no difference can you run this on the ASA and then post the results and someone else may be able to help or i'll check in tomorrow -
"packet-tracer input outside tcp 8.8.8.8 12345 1.1.1.35 http"
Jon
Again, thank you.  I changed the ACL syntax to what you're familiar with and it still doesn't work.  Is it possible my site-to-site IPSec VPN is getting in the way?  Here's the output from the command you requested:
# packet-tracer input outside tcp 8.8.8.8 12345 1.1.1.35 http
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
NAT divert to egress interface inside
Untranslate 1.1.1.35/80 to 192.168.253.70/80
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-list outside_access_in extended permit tcp any object Svr-HTTP eq www
Phase: 4
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
 match default-inspection-traffic
policy-map global_policy
 class inspection_default
  inspect http
service-policy global_policy global
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
  inspect waas
Phase: 8
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 9
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 11
Type: NAT
Result: ALLOW
Config:
Phase: 12
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 13
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 1214, packet dispatched to next module
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
The packet tracer output shows that your configuration is working.
Can't comment on the VPN because you haven't included that.
Does the web server have it's default gateway set to the ASA ?
Can you connect to the web server successfully from inside ?
Jon
Sorry for the delayed response.  Yes, the ASA is the one and only gateway on all inside hosts.  No inside hosts have a problem getting to the internet.  There are actually three servers with NAT rules, an Exchange server, FTP server and this web server.  All have the same problem.
Would it be possible for me to privately send you a copy of my entire configuration and see if something jumps out at you?
