Ping PIX help - two ip addresses on pix outside interface?
cybrsage
Here is my situation:
I have a pix 515E currently running with private IPs on both the outside and inside interfaces. I now have to have the outside interface pingable from the Internet and cannot figure out how to do it.
This is what I thought I needed to do:
z.z.z.z is the Internet address of the person who needs to ping my pix
a.a.a.a is the new Internet address I am trying to use on the firewall.
10.0.0.1 is the inside interface
access-list outside_access_in permit icmp z.z.z.z host a.a.a.a
static (inside,outside) a.a.a.a 10.0.0.1 netmask 255.255.255.255 0 0
It does not work.
I was thinking maybe I just need a second ip address on the outside interface, but really have no idea.
Thanks!
21 Replies 21
Nope, that would be too easy. :)
I know the range makes it to my firewall, so at least that part of the problem is not an issue.
Thanks for all your help.
I've set it up in the lab, but I can't do it exactly with the hardware I have. I did do some searching on the internet and it looks like this will work. You need to create a management interface-
vlan 44
nameif management
ip address 192.168.1.50 255.255.255.0
Then create a NAT from one of your public IP's to the management interface.
static (management,outside) [public IP] 192.168.1.50 netmask 255.255.255.255
The port needs to be up, so I would plug it into a null VLAN so the can't get anywhere else when they SSH in.
Excellent, I will try it tomorrow and let you know.
Thank you for all your hard work!
I was just able to try this, but I cannot use the vlan command. It is not recognized.
I am running 6.3(3)
How do I this up? My google-fu is low today and I cannot find any info on it.
Ahh, just use a new interface instead of the VLAN.
I am going to have the outside monitoring group test it soon, but this is what I added:
a.a.a.a is the legal IP address they will be using to connect.
access-list outside_access_in permit tcp object-group outside_servers eq ssh host a.a.a.a eq ssh
access-list outside_access_in permit tcp object-group outside_servers host a.a.a.a
access-list outside_access_in permit icmp object-group outside_servers host a.a.a.a
static (inside,outside) a.a.a.a 1.1.1.1 netmask 255.255.255.255 0 0
int ethernet5 nameif management 10
ip address management 1.1.1.1 255.255.255.255
int ethernet5 100full
The 1.1.1.1 is then blocked by an access-list on the switch to which it connects.
Does that look like it should work?
Looks good. Your first two ACLs can be replaced by one that is more secure-
access-list outside_access_in permit tcp object-group outside_servers host a.a.a.a eq 22
