PIX 501 - How to use public (WAN) IP for Dynamic NAT to inside server?
bregimand
I've tried several forum suggestions, PDM & command line changes to no avail. I have 1 Small Business Server behind a PIX 501 & I need to forward 5-6 ports (web, smtp, pptp, ftp, termsvcs, dns)to the SBS (192.168.10.11). The 1 public IP is the WAN port of the PIX. Think of this as a DSL/Cable connection with a small bus. server behind it. I'm having a very hard time with both the PDM & command line configs. Please help!!!
PIX 6.3(3) - PDM 3.0(1)
As you can see, I've also tried an object-group with the needed ports.
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
clock timezone CST -6
clock summer-time CDT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 192.168.10.11 GeckoSBS
object-group service SBS tcp
port-object eq www
port-object eq pptp
port-object eq ftp-data
port-object eq pop3
port-object eq https
port-object eq ftp
port-object eq smtp
access-list outside_access_in permit tcp any host 10.20.30.2 eq www
access-list outside_access_in permit tcp any host 10.20.30.2 eq smtp
access-list outside_access_in permit tcp any host 10.20.30.2 eq pptp
access-list outside_access_in permit tcp any host 10.20.30.2 eq ftp
access-list outside_access_in permit tcp any host 10.20.30.2 eq 3389
access-list outside_access_in permit udp any host 10.20.30.2 eq tftp
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 10.20.30.2 255.255.255.252
ip address inside 192.168.10.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 0.0.0.0 255.255.255.255 inside
pdm location GeckoSBS 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface www GeckoSBS www netmask 255.255.255.255 0 0
static (inside,outside) tcp interface smtp GeckoSBS smtp netmask 255.255.255.255 0 0
static (inside,outside) tcp interface pptp GeckoSBS pptp netmask 255.255.255.255 0 0
static (inside,outside) tcp interface ftp GeckoSBS ftp netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 3389 GeckoSBS 3389 netmask 255.255.255.255 0 0
static (inside,outside) udp interface tftp GeckoSBS tftp netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 10.20.30.1 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:00:00 sip 0:00:00 sip_media 0:00:00
timeout uauth 0:05:00 absolute
ntp server 140.221.8.88 source outside
http server enable
http 192.168.10.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
no snmp-server enable traps
floodguard enable
telnet 192.168.10.0 255.255.255.0 inside
telnet timeout 5
17 Replies 17
ggriffin
Bregimand,
Would you be so kind as to post, or email me your final config? I have the exact same scenario and I am having a difficult time getting port 443 through for secure webmail on the sbs server.
I'd love to compare my config with yours. Feel free to email me at ggriffin@nucentric.com. Thanks in advance!!!!
Gary
Gary,
If you want to port-forward tcp port 443 using the interface IP, you must disable the PIX PDM GUI http server:
no http server enable
Correct, I have disabled http management on the outside interface. The management of the PIX is now done after establishing a VPN tunnel & terminal services on a LAN machine.
I've been reading that even SSH from the outside is not recommended. Anyone have any success enabling SSH on the WAN side?
