PIX 501 Problem
rvr_76bg
Level 3
Level 3
Hello All,
I have a PIX 501. I configured it with Public IP add outside and private IP inside. I am able to connect to the device fron inside via telnet but NOT from outside. I configured the telnet access on both Interfaces with telnet command. I am able to connect to the device from outside but only via HTTPS://. Can you help me guys? Do I have to use static command with port 23??
Rumen
acomiskey
Level 11
Level 11
Pix doesn't allow telnet on the outside interface, you must use ssh.
Thank you very much.
