Pix 515 4-port ethernet interface issue
neal.miller
Why does my PIX not see all 4 ports on the 4 port ethernet interface card. It only sees 1. Here is a sho ver
Result of firewall command: "sho ver"
Cisco PIX Firewall Version 6.3(4)
Cisco PIX Device Manager Version 3.0(2)
Compiled on Fri 02-Jul-04 00:07 by morlee
itf-gw-01 up 56 mins 18 secs
Hardware: PIX-515, 32 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 16MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: ethernet0: address is 0003.6bf6.88ef, irq 11
1: ethernet1: address is 0003.6bf6.88f0, irq 10
2: ethernet2: address is 000d.88ef.43dc, irq 9
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Enabled
Maximum Physical Interfaces: 3
Maximum Interfaces: 5
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has a Restricted (R) license.
serial number omitted
Running Activation Key: omitted
Configuration has not been modified since last system restart.
Thanks all
jboyer
You have a Restricted license. You need the Unrestricted license for more than 3 total interfaces. You can purchase a R-UR upgrade license, enter the new key and viola, all your interfaces will work!
richcobb99
I had the same problem. You need to have an UR or unrestricted license for the 4 port card to work. You have an R or restricted license.
Hope this helps.
rich
