PIX 515E Failover help
DanielO
Community Member
Hello everyone,
What is the best way to setup the PIX 515E for FO? I read that serial + ethernet is the best way to go, this seems to be what I want to do.
How do I go about setting this up in this manner? Thanks for your help. I get bad search results when looking on the cisco site, so I figured I would post here and save myself some grief.
mark.hodge
Level 3
Level 3
Assuming you have Version 7 software, Cisco have it covered here.
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a008045247e.html
As you state, serial heartbeat plus dedicated statefull link ( peferebly a VLAN ) is the best way to go. For this the two devices need to be withing 6 feet or so of each other.
Later versions of ASDM have a reasonable GUI, just make sure the hardware and software is identical, and also the encyption licences need to be the same.
