PIX 515E setup problems... please help!
enpop1
Community Member
Hi... hopefully someone will be able to help a PIX newbie like me... here's the problem. I am moving from an ISA 2000 firewall server to a PIX 515E. Our network is on a 10.0.0.1 - 10.0.5.254 "network." I have two lines to the internet, however, which I am connecting to via a dual router... Xincom XC-DPG602. The internal IP address for this router is 192.168.1.3, and through the ISA server, I have internet access. The external IP addresses for my internet lines are through earthlink (T1) (208.29.018.xxx) and Time warner (Cable) (70.60.48.xxx). They are being load balanced through the Xincom router, which is why I went with a "dual" router such as this. I will admit, I am pretty new at configuring PIX firewalls, so I figured I'd try to use the PIX default settings (it says it is configured for small business out of the box), but it wouldn't work. When I try to change the inside or the outside interfaces though (from the terminal or from the PDM interface, I usually get errors of some kind and still nothing goes through. I have tried to read what I could from the internet, but I just can't seem to make any headway. If this makes any sense to anyone, I hope you will help me out.
Thanks!
Eric
10 Replies 10
nkhawaja
Where is the NAT happening? basically these are all you need
ip address inside
ip address outside
route 0 0 outside 192.168.1.3
nat (inside) 1 0 0
global (outside) 1 interface
(For the traffic to flow from inside to outside)
enpop1
Community Member
Hi... thanks for your reply. I have the current configuration of the PIX listed here, but it is not working. When I try to set the inside ip address to something other than 192.168.1.1, it tells me that it conflicts with the DHCP pool, or something along those lines. Does any of this make sense? All I need to do is provide access to the internet for our inside users. I do not have a dmz as of yet or anything "special," and I do not want to use DHCP from this firewall, since I already have a dhcp server on my network. Thanks again for the help.
Switch>write term
Building configuration...
: Saved
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security4
enable password xxxxx/xxxxxxxx/ encrypted
passwd xxxxxxxx.xxxxx encrypted
hostname pixfirewall
domain-name cathedral-prep.com
clock timezone EST -5
clock summer-time EDT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
<--- More --->
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
pager lines 24
mtu outside 1500
mtu inside 1500
mtu intf2 1500
ip address outside 192.168.1.3 255.255.255.255
ip address inside 192.168.1.1 255.255.255.0
no ip address intf2
ip audit info action alarm
ip audit attack action alarm
pdm location 10.0.1.0 255.255.255.0 inside
pdm location 10.0.2.0 255.255.255.0 inside
pdm location 10.0.3.0 255.255.255.0 inside
pdm location 10.0.4.0 255.255.255.0 inside
pdm location 10.0.5.2 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 10 70.60.48.238-70.60.48.248
<--- More --->
global (inside) 200 10.0.5.2
nat (inside) 10 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
route inside 10.0.1.0 255.255.255.0 192.168.1.3 1
route inside 10.0.2.0 255.255.255.0 192.168.1.3 1
route inside 10.0.3.0 255.255.255.0 192.168.1.3 1
route inside 10.0.4.0 255.255.255.0 192.168.1.3 1
route inside 10.0.5.2 255.255.255.255 192.168.1.3 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
http 10.0.1.1 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
<--- More --->
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
terminal width 80
Cryptochecksum:xxxxx
: end
[OK]
pixfirewall(config)#
You'll need to disable dhcp on the firewall first, to do this issue in configuration mode:
no dhcpd enable
This will stop dhcp on the firewall, you can also clear the other dhcp commands by issuing 'no' i.e. no dhcpd lease 3600 etc. Do this from CLI under config mode and save with write mem.
You can find the step-by-step setup guide here:
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_command_reference_book09186a008017284e.html
Look at section: Establishing Connectivity.
Let me know how you get on or require further help.
Jay
Also forgot to add this attachment for you, this explains the six basic steps required to setup a PIX. Hope it helps out.
Jay
enpop1
Community Member
Hi... the attachment helped me understand a bit more - thanks. I am still running into connection problems, however. I posted my now current configuration out on this thread... I would appreciate any help with looking through it and seeing if I am still missing something. I still cannot establish an internet connection through the PIX.
Eric
First clear the dhcpd parameters, the command is "clear dhcpd"
then do whatever you would like to with the IP addressing .
Nadeem
enpop1
Community Member
Hi... this is what I have now for my configuration on the PIX, but for sme reason, I am still not able to get internet access through it. Can someone look at this configuation and hopefully let me know if it should work or if I am doing something wrong? Thanks again...
Eric
oh, and if you read through this, the 192.168.1.3 address is the internal "gateway" address of my router. My network basically has PCs with IP addresses ranging from 10.0.1.1 - 10.0.5.254 on it as well, if this helps.
wri term
: Saved
PIX Version 6.3(3)
passwd xxxxx
<--- More --->
names
pager lines 24
mtu outside 1500
mtu inside 1500
mtu intf2 1500
ip address outside 192.168.1.2 255.255.255.0
ip address inside 10.2.1.1 255.0.0.0
no ip address intf2
pdm history enable
arp timeout 14400
nat (inside) 1 10.0.0.0 255.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 192.168.1.3 1
<--- More --->
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxxx
: end
[OK]
hi,
what exactly is not running? any kind of traffic to the internet? ping wont work unless you add
access-list 100 permit icmp any any echo-rely
access-group 100 in interface outside
can you access any site via its IP? Where is your DNS? after adding the above commands I told you, can you ping the 192.168.1.3 1 from any inside PC?
IF that works, there PIX is Ok as far as the config.
enpop1
Community Member
Hi...
I added these lines, and though I can ping the PIX, i cannot ping through the pix to the router. I have a dhcp server on the network (10.0.0.82) and I have tried pinging through to other web sites - google.com, msn.com, etc - but it comes back as host unreachable. I tried this from four different PCs in the building. Do I have to add something to the pix for DNS?
what lines? the acccess-list lines? if you are on the PIX, can you ping your default gateway right from there? there is nothing much left in the configs.
what does "show interface" says? are the interfaces up?
