PIX 515E with OS 7.0(4) Failover Issue ... HELP !!!
scheikhnajib
A weird thing I'm facing here. I have a lot of PIX-515E-UR units coupled with FO units all of them running PIX OS 7.0(4).
All my PIX units are using serial failover and have an additional NIC that is used for stateful failover.
A while ago I got two new couples that have 6 interfaces and I started seeing a lot of problems on both of these couples like:
1- The primary unit keeps writing config to the failover with a high frequency (every 5-10 minutes)
2- The primary unit fails over without any reason.
3- The units are getting reloaded without any intervention and without any reason.
It is the same Hardware platform with the same OS version, the only difference is the number of interfaces ... ???!!!
Any ideas? recommendations?
I'm confused here ...
Thanks.
Salem.
benny.jr
Have you try to disable default inspections for http?
I have no inspection running on these new pairs. Only "icmp error" to allow traceroute.
Thanks.
Salem.
