Pix 525 hardware problem?
m.belateche
Community Member
hello
when powered on the pix will display the following message and then stop booting up:
CISCO SYSTEMS PIX FIREWALL
Embedded BIOS Version 4.3.207 01/02/02 16:12:22.73
Compiled by morlee
256 MB RAM
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
00 00 00 8086 7192 Host Bridge
00 07 00 8086 7110 ISA Bridge
00 07 01 8086 7111 IDE Controller
00 07 02 8086 7112 Serial Bus 9
00 07 03 8086 7113 PCI Bridge
00 0D 00 8086 1209 Ethernet 11
00 0E 00 8086 1209 Ethernet 10
00 11 00 11D4 2F44 Unknown Device 11
what could be the issue? how to solve the problem?
thanks
m-haddad
Level 9
Level 9
Open the PIX and inside you will find a battery. Remove the battery for few seconds and of course remove the power plug.
After that insert the battery again and power on and you should be UP.
PLease rate this post if solves your problem,
m-haddad
Level 9
Level 9
RobbyCauwerts
Community Member
I've had the same problem last week.
Opening a RMA was the only solution.
Kr.
Robby
