PIX 525 speed problem with MySQL
1writeson
Hi all,
Our network services group just installed a new Cisco PIX 525 firewall
(software version 7.0.1) at one of our mirror sites. This system is
working well, except in one case that I can't resolve. All connections
and protocols are working well except for MySQL throught the VPN back
to our office. If we try to do activity like this:
select * from table;
over the VPN connection, the speed of that transaction becomes horribly
slow to the point of failure. Our standard system is a RedHat
Enterprise Linux machine running MySQL 3.23.58 which has run without a
problem prior to the installation of the PIX firewall. We've
installed MySQL on a Windows and Solaris machines as a test and they exhibited the
same problem. It seems to be related to the small packet size used by
MySQL for the above select statement transaction. Table export/file
imports in MySQL seem to work at a normal speed, it's only the small
packets generated by the select statement that seem to be a problem.
Does anyone have any ideas/suggestions I might recommend in order to
address this problem?
Doug Farrell
mmellet
Level 3
Level 3
You need to check the release notes for any caveats for this.
Thanks for the reply, though not that helpful as my Network Services Group has the release notes and isn't very forthcoming with that kind of information. I'll look around the site and see if I can find anything about that, however, I haven't seen anything specific for version 7.0 of the software.
Thanks again,
Doug
