PIX DMZ traceroute problem
wilsonyong
PIX config:
hostname ASA5520
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 202.101.2.X 255.255.255.248
interface GigabitEthernet0/1
nameif dmz
security-level 50
interface GigabitEthernet0/2
nameif inside
security-level 100
ip address 172.10.1.1 255.255.255.0
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list outside_access_server extended permit tcp any host 202.101.2.Y
access-list outside_access_server extended permit icmp any any
access-list dmz_access_inside extended permit ip any any
access-list dmz_access_inside extended permit icmp any any
access-list inside-accesss-dmz extended permit icmp any any
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any dmz
icmp permit any inside
global (outside) 1 interface
nat (inside) 1 172.10.1.0 255.255.255.0 tcp 400 300
static (dmz,outside) 202.101.2.Y 192.168.1.10 netmask 255.255.255.255 dns
static (inside,dmz) 172.10.1.0 172.10.1.0 netmask 255.255.255.0
access-group outside_access_server in interface outside
access-group dmz_access_inside in interface dmz
access-group inside-accesss-dmz out interface dmz
route outside 0.0.0.0 0.0.0.0 202.101.X.X
timeout xlate 8:00:00
timeout conn 24:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:00:00 absolute uauth 3:00:00 inactivity
class-map tcp_allow
match access-list acl_tcp
class-map type regex match-any testhttp
class-map down
match access-list download
class-map inspection_default
match default-inspection-traffic
policy-map down
class down
police input 2048000 512000
police output 2048000 512000
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect http
policy-map tcppolicy
class tcp_allow
set connection advanced-options conform_tcp
service-policy global_policy global
service-policy tcppolicy interface outside
problem description:
1、inside client can traceroute to internet.
2、inside client can traceroute to DMZ server.
3、DMZ server can not traceroute to internet and inside client.
ex_pmadayag
1.) DMZ to client communication:
I could only see translation for 172.10.1.0 network
You also need to have translation for the 192.168.1.x network. Then do a clear xlate.
2.) DMZ server to Internet
Can the DMZ server reach the gateway? Defined in this line?
If you enable debugs what do you see?
