PIX Failover Problems
evantol
I have two PIX515 firewalls. One has a UR license and one has an FO license. I am not using LAN-based Stateful Failover and running 7.0(2) software.
My problem is that the failover doesn't seem to be working properly. I appear to be able to failover to the secondary unit fine, but if I do anything at all to the primary unit (which is in Standby according to 'show failover' output), I can no longer pass traffic on the Secondary (now primary) unit.
For instance - if I simply unplug either of the ethernet interfaces on the Primary, I can no longer ping the default gateway on the inside interface and thus cannot pass traffic through the Active firewall. If I turn off the Primary, I cannot pass traffic through the Active firewall. If I disable failover entirely and disconnect the serial cable, I still cannot do anything to the Primary, or I end up losing connectivity.
From what I can see, everything is configured properly and there's not really any complicated options to set when configuring failover. The failover config is below:
failover
failover polltime unit 1 holdtime 3
failover polltime interface 3
interface Ethernet0
speed 100
duplex full
nameif outside
security-level 0
ip address 192.168.1.10 255.255.255.240 standby 192.168.1.11
interface Ethernet1
speed 100
duplex full
nameif inside
security-level 100
ip address 10.200.0.1 255.255.255.248 standby 10.200.0.2
Is there something I'm missing?
nkhawaja
can you send output of show failover from both pix
can you send output of show interface from both pix
thanks
Nadeem
Sorry for the late response. The output has been attached.
jwalker
Level 7
Level 7
Are you doing Serial Cable Based Stateful Failover? If so, make sure the serial cable is connected to the appropriate FW. The ends are marked Primary and Secondary. Next, you need to setup the rest of the failover... like:
nameif ethernet4 FAILOVER sec50
interface ethernet4 100full
ip address FAILOVER 172.16.4.1 255.255.255.0
failover ip address FAILOVER 172.16.4.2 255.255.255.0
failover
failover ip address outside 192.168.1.11
failover ip address inside 10.200.0.2
failover link FAILOVER
I am not doing stateful failover, as I mentioned in the original post. The cable is plugged in properly. It would generate an error if it wasn't.
