PIX flash space problem v7
Nickfulstow
Community Member
I have just loaded a new pix v7 image on a 525 PIX.
PIX721.bin 8k
asdm-506.bin 5.6k
I am unable to tftp a asdm-506.bin image I get a the error (Not enough space on device)
Directory of flash:/
5 -rw- 8202240 07:34:12 Nov 20 2006 pix721.bin
16128000 bytes total (7919616 bytes free)
Deskpix# sh mem
Free memory: 198964296 bytes (74%)
Used memory: 69471160 bytes (26%)
Total memory: 268435456 bytes (100%)
As you can see there is loads of space but I am unable to copy the .bin file
I have formatted the flash and deleted all files that Im able to see ?
Any suggestions would be welcome.
Nick
john.elias
Community Member
Nick, what is the command you are using to upload the image. You should be using...
asdm image
Nickfulstow
Community Member
All resovled now.. I used a earlier code and asdm code and it works.
