PIX Interface problem
brian.oflynn
Level 3
Level 3
Hi, I am having a problem with the inside interface of my failover pix. It is showing up/up on the pix and on the switch it is connected to. If I do a show arp, I can see the mac and ip ok. When i try to ping the ip from the switch however it does not respond. This was working previously and nothing has been changed. It just dropped off our monitoring and hasn't worked since. I have put it through the output interpreter but don't see anything. When I do a show failover on the primary, it says normal(waiting) for the inside of the failover pix. I have changed the cable connected to the inside interface but still the same. I can ping the failover interface from the primary pix ok. Any ideas?
a.kiprawih
Level 11
Level 11
From the switch, you can't ping the active PIX IP but the standby status was ok?
Can you share the failover config? And for a quick check, are the inside interfaces sits in the same Vlan on the switch-side?
